2007 HHR AC Issue
Old Jul 18, 2014 | 06:36 PM
newtconn's Avatar
2007 HHR AC Issue
Hi, my husband replaced and recharged the AC compressor in his 2007 HHR, he found a leak and thought that would fix the AC blowing hot. It has not, the air still blows hot, any suggestions? He was driving along in the Las Vegas sunshine, the temp gauge in the duct was reading 40 degrees, then everything went hot....
The cooling fan near the radiator still engages, the coolant temp is still reading a decent degree range, highest read was 214 degrees.
Any suggestions, the shop manual just makes both our heads spin....so many variables. He's been out of work so we are trying to avoid the dealership...
Thanks,
Old Jul 18, 2014 | 06:46 PM
So he replaced the compressor, recharged the freon. Did he reset the computer by disconnecting the battery negative in the trunk? You mention the temp 214 degrees do you mean the coolant gauge? Perhaps changing the Thermostat is in order it should be
Lower at 180 to 195 trial and error I suggest the battery disconnect first
Old Jul 18, 2014 | 06:58 PM
Without knowing the compressor readings after the work was completed, kind of hard to attempt a guess.
Ask your husband what the gauges were reading after pulling the vacuum and recharging with freon.
Old Jul 18, 2014 | 08:24 PM
My very first thought is : did anybody ever think to replace the coolant t-stat (and coolant at 150K or 5 years WCF)?
Second thought is : what about the blend door?
Old Jul 19, 2014 | 07:56 AM
I suggested the t stat in post# 2 , Don but blend door is a good shot
Old Jul 21, 2014 | 07:00 AM
Another 1 time poster that hasn't come back. Guess it wasn't that important.
Old Jul 21, 2014 | 08:37 AM
I feel so used and disrespected when that happens, but maybe the issue is resolved and they're out driving the HHR
plovell66
Aug 4, 2016 07:07 PM
HHR Mum
Aug 16, 2008 09:09 PM
gcsd3742
Jul 25, 2008 11:10 AM
Lone Ranger
Aug 4, 2007 06:38 PM
GDZHHR
Apr 6, 2007 01:47 PM
