2007 key fob - original fobs
Old Mar 12, 2017 | 11:06 AM
Php's Avatar
Php
I have a key fob issue. None of the functions will work on either key fob. (Yes new batteries in both)
ive looked through the forums and everyone says a tech 2 scanner is needed to reprogram a fob. These are the original key fobs tho. I don't necessarily need a re program but a relearn.
I think the 08+ have a relearn feature within the odo/cluster but I'm not seeing this on my 07.
i believe, but someone correct me if I'm wrong. I think the battery went dead in the car and caused this key fob issue. But not 100% sure. Any help would be greatly appreciated. Even tho I'm a dodge man, I love my vette and this hhr seems like a wonderful daily for me.
thanks
-Phil
Old Mar 12, 2017 | 11:19 AM
Welcome to the site, check the battery cage , they are known to break, a simple job to solder .
My 2007 had dead main battery issues, it did not mess up my key fobs!
And here's some pictures of the repair
https://www.chevyhhr.net/forums/how-...-repair-22641/
Old Mar 12, 2017 | 11:38 AM
Php's Avatar
Php
I was afraid the dead Main battery was inaccurate.
But yes. One of the key fobs is broken on the inside. I plan on fixing that later today..
im really not sure what's wrong with the other one.. I think I seen somewhere to check #56 fuse under the hood?
Old Mar 12, 2017 | 11:49 AM
Hi Php, to the forums!!
Have a look at this https://www.chevyhhr.net/forums/prob...eap-fix-28165/
And this https://www.chevyhhr.net/forums/how-...ontacts-30813/
Old Mar 12, 2017 | 01:49 PM
Php's Avatar
Php
I was able to fix both remotes!! Thanks everyone!
the metal battery holder was broken.. and the contacts on one remote were worn! Common problems as it seems. Both work perfect now tho
thanks again
Old Mar 12, 2017 | 01:52 PM
That's good news, glad it worked out!! And thanks for updating your thread with results, might help someone down the road!!
Old Mar 13, 2017 | 07:51 AM
Great , enjoy the ride!!
Don Juan
Maintenance and Upkeep
10
Mar 31, 2017 02:39 AM
rharrison
Nov 30, 2009 09:59 AM
Redshift
17
Nov 17, 2008 10:37 AM
RUDEINC
Oct 28, 2006 12:51 AM
