2008 5 spd reverse engagement
Old Jan 21, 2013 | 11:10 PM
Captainrelay's Avatar
Has anyone had problems with reverse not always engaging with the 5spd? Cables etc seem OK and operating the levers at the transmission make no difference. Sometimes it just grinds; 67K miles.
Old Jan 22, 2013 | 04:22 PM
Lucky's Avatar
I have not had any grinding problems with mine. Try putting into 1st gear then shifting to reverse. The clutch disc my be sticking to the flywheel a bit.
Old Jan 23, 2013 | 05:39 PM
Laco's Avatar
Seems to me, that if it was a clutch plate sticking to the flywheel, he would have the same problem getting it into first at a dead stop. Could be reverse syncro's are worn, and if it is a plate sticking to the flywheel issue, the synco's in first may be strong enough to overcome it, but not in reverse. Just throwing guesses out here. Long distance diagnosis is always iffy at best.
Old Jan 24, 2013 | 10:18 AM
IgottaWoody's Avatar
Dont believe reverse has synchros...which would indicated a sticky plate..fwd gears are synchro'd so they will compensate for this, sometimes depending on severity you might actually feel a slight fwd tug as it goes into 1st gear.
Old Jan 24, 2013 | 11:13 AM
HHR_Mike's Avatar
After the vehicle is parked for a while, sometimes my SS grinds and jumps slightly when I put it in reverse. I just put it in fourth gear before putting it into reverse and that prevents the issue from occurring.
Old Jan 24, 2013 | 06:59 PM
Laco's Avatar
Actually reverse does have synchros, surprising, but true.
Old Feb 2, 2013 | 09:55 PM
Internal Problem (apparently)
I ended up at the dealer who admitted having worked on the trans just before I bought it! They agreed to fix it under the GM warranty (5yrs/100K mi). To date they say they have found broken components inside. Haven't got it back and am hoping to see the failed parts. THANKS all who responded!
gio89kid
Mods - Exterior
10
Mar 21, 2015 12:16 PM
lox8691
Mar 16, 2015 09:57 AM
lox8691
Drivetrain (Excluding Engine)
Mar 15, 2015 06:08 PM
Rice Reaper
Jul 20, 2011 12:07 PM
COOK E
Apr 5, 2010 08:50 AM
