2008 ac intermittent
Assuming Don's question is directed at OP, but I had scanned for codes with the car running. No codes at all. The coolant rises quickly to at least 180F from a cold start.
The reason P0128 is intermittent is that it depends on the time it takes to reach 179F, it runs each time the engine is started and clears itself each time the engine is shut down. If you drive the car to the store and then start it back up to go home it will already be warmed up and take less time to reach 179F Likewise, if the ambient temp is in the 100s.
P0128 clears itself when the condition no longer exists, i.e. the second start of the day. That is why I asked if it was checked while the AC is malfunctioning; otherwise it is something else, like the pressure switch.
If the running temp is below 179F I would expect to see P0128. The function of the t-stat is to keep the coolant temp ABOVE 180F and to get there quickly. It is a emissions thing; better combustion at higher temps. The AC not functioning is a way to alert the driver that the EPA is peeved at them.
Updated
Just wanted to give an update to this thread. It’s been quite a while. The car stranded me with a dead battery I replaced the battery and the AC started working perfectly not sure why, but that seems to have fixed it
