2008 HHR dors won't lock/unlock with fobs or switches
Old Sep 17, 2015 | 07:03 AM
PCox's Avatar
Back in service! Thanks to Reynolds Wrap!
Well, I had the exact opposite problem (locks would work, but unlock would). I read the comment above about putting a little foil behind the button and Viola! I'm back in action. And I was about ready to take it to the dealership for another one. Thanks for the help.
(New to the forum and to HHRs so this is a great resource!)
Old Sep 17, 2015 | 07:09 AM
PCox, welcome to the site, glad to have you here!
Old Sep 17, 2015 | 08:37 PM
gazar53's Avatar
driver door lock problem
My doors lock fine with the automatic lock, but there are times my key will not unlock the door. So when I lock my car I have to use the lock button but before I close the door I have to check and make sure my key will unlock and then lock the door. If I dont do this I take the chance of the door not unlocking with the key when I'm ready to go. My key fob worked but it broke about 8 months ago, have to get a new one and see if it will solve the problem. Any suggestions on what to check or do with the lock using my key?? Thought of just replacing the whole locking mechanism in the door.
Old Sep 18, 2015 | 07:19 AM
A spray of lube to the lock should loosen things up.
Take your FOB into local auto parts store like AutoZone, or Advance Auto to have it tested
It could just be a broken battery bracket
Old Sep 19, 2015 | 05:42 PM
Don06's Avatar
Originally Posted by Glanden
My wife just called to say that she was able to unlock the doors with the fob once and now it sounds like it's blown again. I'll see about tracing wires when I get home, but I don't know where to start tracing from or anything. It may be time to call in an electrician. No damage or water spills that I'm aware of. Thanks again for the speedy response.
You could try replacing the fuse with a circuit breaker that will automatically reset. I suspect either one of the actuators is failing, there is some rust or corrosion that makes one or all pull harder or a short in the wiring somewhere. Eventually it will be continuously shorted or one actuator will quit working.In the old days I would put a 20 amp fuse in but it could damage the BCM. You can remove the door panels to check for any problems and lube the linkages with graphite or a molybdenum lubricant.
I assume it is the mini fuse but both types are available.
Old Sep 23, 2015 | 06:18 PM
Glanden's Avatar
I may have to look for those. It is the mini fuse and I've placed a 20 AMP fuse in there now and it seems to be working, but if this is a better/safer alternative I'll do this instead. I didn't see these at the auto store I went to, do you know where I can find them?
sky
Mar 22, 2018 10:44 PM
whispery
Jan 2, 2015 06:38 PM
oneton
Mar 14, 2012 02:02 PM
ibdcaptain
Oct 27, 2009 01:33 PM
