2009 HHR automatic transmission issue…
Looking at this car….lady says transmission is bad…soleniods….but also says reverse works fine, no forward gears…,.1st gear quit working first then week or 2 later no forward gears…says not driving on road only in yard.
What is most likely probable cause? Trans totally shot? Soleniods bad (both)….or flyid tubes broken?
Thanks
Thanks
Well, I had thought about checking resistance of the shift solenoids first. Then maybe drop pan and check the fluid pressure tubes but really I am not an automatic transmission guy…..was hoping for some useful imput….lol
That's what I would do... at the right price. Bet they already know what the local scrap value is. $200-400 around here. $100 over that should buy it. You're taking a risk, so that's fair.
