2009 HHR Power Steering Motor
Old Mar 7, 2020 | 09:02 PM
cfipilot's Avatar
Well then, that sucks. So i guess i will contact a couple more dealers, and if nothing else, replace it myself.
Old Mar 7, 2020 | 09:24 PM
one was recalls where 14115 was present and cleared.
What does that mean "cleared"? 11415 is for all 2009-2010.as is stated in the Official recall letter that went to owners of record. (the second link above)
If they can't find it on GM they certainly couild download it from NHTSA.gov. You can call GM Regional; just go to the local Service Manager not the pinhead service writer and ask for contact info.
Old Mar 7, 2020 | 09:30 PM
cfipilot's Avatar
Clear means that it was completed.
Old Mar 8, 2020 | 09:34 AM
Well, then it has been done once. You need to figure out if they used old stock parts or the new part. If it was the old part that is specifically covered.
The good news is the motor is under $100 and 15 minutes work, if you know which end of the butter knife to use as a screwdriver.
https://www.ebay.com/sch/i.html?_fro...temCondition=3
Old Mar 8, 2020 | 10:57 AM
This might be the ticket!
https://www.chevyhhr.net/forums/clas...w-motor-62684/
Old Mar 8, 2020 | 07:57 PM
cfipilot's Avatar
So went back out to the car, QQ: SHould i feel the steering wheel harder to move? Because i Dont. It feels like a normal wheel with power steering. Im old enough to know what a non power steering wheel feels like.
So tomorrow when i got back out i will pull the 60 amp fuse and feel the wheel.
Lets assume that the motor is working, what else would trigger the "power steering" message on the dash?
Old Mar 9, 2020 | 05:11 AM
Cat Man HHR's Avatar
I did some reading on this and have questions.
Why isn't a check engine light on for this ?
Only non turbo HHR's 2009-2010. Why not the SS ?
Why early years don't have this issue ?
As someone on this forum said "the dealer only took 10 minutes to fix the problem" that's a fuse change to me.
It isn't hard to just change the electric motor, if that's the backbone to the problem. But how to prove it ?
Old Mar 9, 2020 | 05:48 AM
Because the SS has a different power steering motor than the LS, LT. The one's on the SS seem to be more durable and rarely fail.
Old Mar 9, 2020 | 07:50 AM
So let’s keep focused on this 2009 LT and it’s issues.
Old Mar 9, 2020 | 08:07 AM
2006-2010 have the same problem. They changed the manufacturer for late 2009-2011, 2009-2010 got a mix of parts.
