2009 HHR Power Steering Motor
Old Mar 9, 2020 | 08:16 AM
Cat Man HHR's Avatar
Originally Posted by Oldblue
So let’s keep focused on this 2009 LT and it’s issues.
These are just questions that maybe can help people with non SS models.
Read the rest of my questions that deal with this issue also.
Thanks.
Old Mar 9, 2020 | 08:20 AM
Because the SS has a different power steering motor than the LS, LT. The one's on the SS seem to be more durable and rarely fail.
Why can't non SS cars use them ?
Or is that the replacement motor that is installed to fix the problem ?
Old Mar 9, 2020 | 08:24 AM
Originally Posted by Cat Man HHR
I did some reading on this and have questions.
Why isn't a check engine light on for this ?
Only non turbo HHR's 2009-2010. Why not the SS ?
Why early years don't have this issue ?
As someone on this forum said "the dealer only took 10 minutes to fix the problem" that's a fuse change to me.
It isn't hard to just change the electric motor, if that's the backbone to the problem. But how to prove it ?
you mean these questions?
the EPS notice doesn’t trigger a code , so no CEL.
my 2007 had this issue, GM replaced the EPS motor and provided an extended warranty as long as I owned the car.
dealer only took 10 minutes, that fuse change is your speculation.
the GM dealership tested my EPS motor before changing it, the technician hooked up the Scan II to read the EPS notice, that’s why the dash notice has to be lit in order for them to proceed.
Old Mar 9, 2020 | 09:04 AM
Only EPA (smog related) codes light the CEL. There are some codes related to the EPS.
Old Mar 9, 2020 | 11:02 AM
cfipilot's Avatar
So Pulled the fused and steering wheel was much harder.
So back to square one. Since the issue is a little different then before i will start a new trend to give myself the best chances.
le2007will
Dec 11, 2016 07:17 AM
SteveMaine
Dec 18, 2015 11:01 AM
07azhhr
Mar 30, 2014 02:57 AM
jrsmith54
Dec 11, 2013 12:51 PM
CHHHR09
Jul 23, 2013 04:09 PM
