2010 HHR abs big problem.
Old Dec 24, 2019 | 10:56 AM
Merged, now go to a shop that specializes in brakes and have the codes pulled.
When you say sensors replaced are you speaking of the hub assemblies at each corner?
it might just be the wires near the hubs, twisted and broken, that can happen running over a branch or replacing a strut!
Old Dec 24, 2019 | 11:18 AM
Tiedupgood's Avatar
Checked wireslo
Car spent most of its time in New Mexico and Arizona. Very little rust, wires seem to be fine
Old Dec 24, 2019 | 11:20 AM
Tiedupgood's Avatar
Hubs and sensors are combined
Replaced all four including brakes
Old Dec 24, 2019 | 11:29 AM
Ok, all four hubs replaced, that points me to wiring harness problems, someone here a little while ago found their ABS sensor wire pinched no far up the wire from the connector near the hub!
Old Dec 24, 2019 | 11:44 AM
If the ABS light is on you can get the codes read, then post the code NUMBERS.
Has the car been in any accidents?
Have the airbags ever deployed?
Has the car ever tipped more than 45 degrees?
Which light comes on when the stop and go is going on, ABS and/or TC?
h
Old Dec 30, 2019 | 09:08 AM
Tiedupgood's Avatar
Abs
I'll get a chance to get a scanned in the next week or so I live in the country so I have to wait till I get to the big city to get it scanned.
Old Dec 30, 2019 | 10:48 AM
We’ll wait!
Old Dec 30, 2019 | 03:32 PM
Blue_SS's Avatar
How is the battery? If this car sits a lot, that might be the only issue.
ABS measures signals in a convoluted way, and if your voltage is low, it kind of loses it's mind.
Really top the battery up, reset these codes, and see if you still see anything. You can't let modern cars sit idle for months at a time without voltage problems.
Old Dec 30, 2019 | 05:37 PM
Tiedupgood's Avatar
Thanks for Replying I have a new battery in it
Old Jan 15, 2020 | 08:46 AM
Tiedupgood's Avatar
I'm going to bite the bullet take it to the Chevy dealer in El Paso today
There is a control module. but is there more than one computer in the brake system. I guess I'm asking is ther a computer for the engine and a computer for the ABS system? Thanks
