Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Found a ABS scanner at a tire shop in El Paso El Paso. Nice guy unbelievable. He tried one scanner and couldn't figure out what was going on. Then he tried another scanner that showed the miles per hour of each sensor. Three of them was doing 25 miles an hour when we were driving the right rear showed 0 miles per hour. Bad sensor bad wiring. So I left the fuse in the system and drove home. No problem with the front right brake grabbing. But all the lights are on. Got home took care of the bad sensor connection. Ended up and no lights were on. I was so happy I went in the house and grabbed a beer. At that point I took it for a test drive. Grumble Grumble grumble the old problem back right front brake grabbing off on off on. The dashboard said ECU active, skid control and abs lights were on also Finally had to take the fuse out again.
I guess it wasn't the connection, it was the hub. While the light is on a ABS scanner can tell which hub it is by the code that is causing the ABS/TC light. Most $100 scan tools can do ABS.
But, you don't seem to actually want advice. We never did figure out how pulling the outside mirror fuse had any effect on the ABS.
