2010 HHR Door ajar light on when all are closed
Old Apr 20, 2015 | 09:00 PM
db/sb's Avatar
Never replaced one but it must be fairly simple because this is all it says in the manual:
Front Side Door Jamb Switch Replacement
Use a small bladed tool to press the tab on the side of the switch to remove.
Disconnect the electrical connector.
Old Apr 21, 2015 | 04:57 PM
Lucky's Avatar
Yep it just pops out with a screw driver. Pull it out unplug it and plug in the new one.
Just pop it back in place and close the door it with automatically adjust
Old Apr 24, 2015 | 05:29 PM
aztrooper's Avatar
Found a YouTube video. It wasn't an HHR but the same switch. Just grab it with a pair of vice grips and pull it out. It breaks off the tabs but the switch was no good anyway. The connector on mine came off inside the pillar so I got my trusty hemostats out and got it out through the hole. Clipped on the new switch and pushed it into place. Kind of scared me when I closed the door because I heard a scraping noise that didn't sound good but when I opened the door, I found that the door closing adjusted the length of the "pin" that sticks out. every thing is good now. Here is the YouTube link.
Old Apr 24, 2015 | 06:23 PM
db/sb's Avatar
Seems I've heard that before
But, seriously, glad you got it fixed!
fbrockel
Nov 4, 2013 04:54 PM
angleplug
Nov 17, 2012 12:05 PM
mo650chopper
Jun 11, 2009 08:24 PM
SIHHR
Sep 9, 2006 11:56 PM
