2011 HHR Climate Control Panel
Old May 15, 2024 | 07:33 PM
Hollywood0723's Avatar
So my wife told me her air stopped working so I replaced the blower motor and resistor after checking the relays. I decided to remove the climate control panel after seeing someone mention “melting” inside the plug. While trying to remove the middle plug, I noticed it was wet. After some work I got it off and noticed some melting inside. Why would it be wet? And besides replacing the CCP, what else do I need to do to prevent this issue again?
Old May 16, 2024 | 07:12 AM
Dielectric grease. Check the ac drain tray for condensation
Old May 16, 2024 | 08:29 AM
I love the wife's description "quit working".
What, exactly does that mean dear? The car does not get cold. Does the fan blow any air? The car does not get cold. Is the air coming from the vent cold? The car does not get cold.
The always give such helpful observations.
If this is a 2006, has the butyl patch been addressed?
is there a puddle of water under the car when running the AC?
Is the temp dial turned all the way blue? My wife thinks centered between blue and red is for AC.
Is the compressor clutch engaging?
Does the fan blow, but only on high?
Do you know the resistor pack goes to ground?
Old May 16, 2024 | 08:55 AM
It’s a 2011.
Old May 16, 2024 | 09:23 AM
Yes, the wifeys description was bad, but I could have done better! So the blower motor wouldn’t engage at all. On AC or heat, nothing would kick on. The AC clutch seemed fine when moving by hand. Haven’t notice any water inside the car (besides it being wet just on that plug I mentioned). In fact, we had a big rain storm and I was laying on the passenger floorboard after replacing the blower motor / resistor and it was dry. I will certainly get some dielectric grease and check the AC drain tray. Hopefully after replacing the control panel, she won’t have any issues with this type of thing as long as she has the car. Fingers crossed!
Old May 16, 2024 | 10:10 AM
There should be a puddle under the car when running the AC.
Open the hood and look at the compressor with your beautiful assistant turning the AC on and off.
Was it water or grease on the plug? I have no idea how water could get there, more likely dielectric grease.
Clevenger87
Dec 4, 2024 03:22 PM
ET65MalibuSS
Oct 7, 2021 07:36 AM
Mhirata808
Sep 20, 2021 06:49 PM
alexrckid
Oct 12, 2018 09:36 PM
Lee3333
Sep 15, 2018 12:48 AM
