2006 No Power to HVAC Blower Motor Control Panel
Old Sep 16, 2021 | 05:28 PM
ET65MalibuSS's Avatar
Trying to fix mom's HHR.
2006 2.2L LT
AC control nob stopped working.
I read a bunch of the threads on here and did all the following.
Repaired the Butyl Patch. No apparent leaks or damage. Live in Arizona so not much rain.
Replaced the resistor under dash by the blower fan.
Replaced HVAC relay #30 in BCM Passenger kick panel under radio.
All fuses test good in kick panel
replaced BCM3 Fuse #4 30amp under hood
swapped relay #50 with #14 and #26 as they are the same part #'s and both those systems still worked. So I assume relay #50 works.
I have NO power to the fan control nob.
Am I missing something? Fuse? Ground?
From what I've read so far I'm suspect of a ground issue 🤔
I've built old cars and wired them but this one has me baffled. All this newer car wiring reminds me why I like the oldies😎
I'd love to take it to a dealer and save my sanity but mom has no money 🤑
Any ideas?
Thanks, ET
Old Sep 16, 2021 | 05:50 PM
to the forums!
You're going to have to be more specific than "nob quit working".
The button won't turn the AC on/off?
You cannot control hot/cold?
Blower motor won't turn on?
Old Sep 16, 2021 | 07:17 PM
Pull the HVAC control panel and inspect for burnt pin connector.
https://www.chevyhhr.net/forums/prob...l-60546/page2/
Old Sep 16, 2021 | 07:34 PM
Thanks for the quick responses
control panel lights all on.
I took the control panel out of the dash thinking it was bad. Tested the plug to the control nob to make sure it was getting power and has no power to any pins with car off/ on and running.
I'm guessing the bigger gauge orange wire should be hot to the switch with key on/running
Old Sep 16, 2021 | 07:35 PM
Might be because it switches ground.
This is a 2006; have you addressed the butyl patch under the cowl? More than likely your problem is a swamped blower motor.
Schematic in this thread: https://www.chevyhhr.net/forums/prob...er-inop-59450/
Old Sep 17, 2021 | 06:34 AM
He says in post #1 he addressed the patch. But lives in Arizona so not much rain. But the motor could still be swamped
Old Sep 17, 2021 | 09:11 AM
PulpFriction's Avatar
Just to cover all the bases, if the fan is turned all the way off, it turns everything off, including the a/c, and hitting the a/c button does nothing.
I had to “fix” this “problem” once.
Old Sep 17, 2021 | 01:13 PM
Lonwane's Avatar
What is a 'nob'?
Where I learned spelling it was KNOB.
Old Sep 17, 2021 | 01:57 PM
Same thing different generation, or speak to text translation
Old Sep 19, 2021 | 10:55 AM
Update to my no power to the "knob" issue. Thank you for pointing out that I didn't proof read🤦
Fan motor works when I ran jumpers from cigarette lighter +/- .
Was going to start tracing power wire to the control panel knob unless someone here has better advice.
Fuses are all good.
Thanks for all the helpful advice so far guys. MUCH APPRECIATED 🙏🏽
ET
