2006 No Power to HVAC Blower Motor Control Panel
Old Oct 6, 2021 | 05:16 PM
  #31
ET65MalibuSS's Avatar
Took it to my trustworthy shop to check freon and trouble shoot.
Freon was empty but nothing wrong within the system to cause that??.
good news is we have ice cold AC and can control it. FINALLY
Any ideas how that can be possible?
It was ice cold prior to the fan motor issue ? ?
Thanks for all your help donbrew
Old Oct 6, 2021 | 05:59 PM
  #32
You probably know, the refrigerant can't just vanish for no reason. If it had no refrigerant in it, then there is a leak somewhere, and if no leak repair was done, it will soon be empty again.
Old Oct 6, 2021 | 06:02 PM
  #33
It went somewhere, no place to hide in the AC system.
Old Oct 6, 2021 | 06:54 PM
  #34
Yeah. Sounds like someone "leaned" too hard on an AC line when working on the fan. Better find the leak source or it will leak out again.
Old Oct 7, 2021 | 06:41 AM
  #35
I expect it to be empty this morning.
They put dye in it and tested it for an hour. I drove it around for about 3 hours.
The only work I did under the hood was the butyl patch repair and testing fuses. Nothing near the Compressor or lines.
Nothing makes sense but I still love learning about cars.
Thanks again guys.
I'll let you know how this ends
ET
Old Oct 7, 2021 | 07:36 AM
  #36
AC lines run just to the right of the under hood fuse box, looking in from the radiator.
RICKJF
Sep 2, 2021 09:23 PM
smittiesplace
Sep 20, 2020 10:42 PM
fatguy_lilhhr
Jun 6, 2019 03:08 PM
Solotreker
Jan 14, 2018 09:24 AM
rb.ctr.vance
Oct 12, 2017 09:27 AM
