2011 LT - Intermittent shudder/stutter in brakes -> ABS light came on
Old Jul 29, 2024 | 06:29 AM
Timewalker's Avatar
This one
Hyper Tough HT500 Bluetooth Scan Tool
https://www.walmart.com/ip/Hyper-Tou...ions/409856222
Old Jul 30, 2024 | 11:38 AM
Timewalker's Avatar
Okay the fuses and relays are all seated properly.
Does the hub hold the wheel speed sensor?
I am wondering if this behavior, combined with the previous post I made about the random "Service ESC" warnings, combined with the odd growling/groaning I am hearing when I turn to the left (see video) is all adding up to "replace the right front hub"?
Old Jul 30, 2024 | 12:12 PM
My last ABS problem was the caliper slide pins, the right side lower pin was seized so the brake wouldn’t apply fully, causing the tire to turn different speed from the left front, and yes tge wheel speed sensors are in the wheel hubs.
Old Jul 30, 2024 | 03:00 PM
And yes probably related. Easy to check hubs: jack the wheel off the ground push/pull on the wheel; if you can sense ANY movement the hub is bad. End play tolerance is 0.001 inch.
Old Jul 30, 2024 | 07:30 PM
PulpFriction's Avatar
Check the sensor wires and connector before you buy anything. The intermittent nature of the problem suggests a bad connection. This is not uncommon.
Old Jul 30, 2024 | 07:34 PM
Timewalker's Avatar
Thanks everyone. I will check tomorrow if the weather cooperates.
Old Jul 31, 2024 | 12:02 AM
tiapetra's Avatar
Originally Posted by Timewalker
This one
Thanks
Old Jul 31, 2024 | 08:02 AM
Does it really read tire pressure?
Old Jul 31, 2024 | 09:25 AM
Timewalker's Avatar
No play at all in the wheel. I'll see about taking it off later and see if I can check the connection. It's already 99 degree heat index this morning.
Old Jul 31, 2024 | 10:41 AM
Timewalker's Avatar
Yes, it does.
