2011 LT - Intermittent shudder/stutter in brakes -> ABS light came on
Old Jul 31, 2024 | 02:48 PM
The wire connection is attached to the strut, you do not need to take the wheel off.
Strange that it reads TP since that is not a OBD2 item.
Old Jul 31, 2024 | 05:21 PM
tiapetra's Avatar
Originally Posted by Timewalker
Ugh. Took it to the shop. They checked the brakes and said mechanically they look great. He test drove it and couldn't replicate the issues. At least I got the oil changed.
Of course it stuttered on the way to Wal-mart right after that. I picked up a new bluetooth dongle from HyperTough that reads ABS codes. The RepairSolutions2 App paired quickly and I got these two codes.C0460-42 - steering wheel angle sensor - calibration not programmed
C0040-0F- right front wheel speed sensor circuit - signal erratic
Well I got the HHT500 and tried the ABS and all it kept saying was that ABS was not available. Would not even go into that module any deeper.
This is on a 2011, so I would think it should be.
Everything else seems fine with 0 engine codes.
Coolant temp was accurate as well as tire pressures.
Old Aug 1, 2024 | 06:39 AM
Most likely wheel hubs.
Old Aug 16, 2024 | 08:43 AM
Timewalker's Avatar
Update - took it into the shop. Managed to get the only HHR front hub in stock within the three nearby towns. Replaced. Driven for a couple hundred miles. No more shudder/stutter. No more ABS codes. No more Service ESC ligh.... crap. Three days without that light coming on, and now it is back on that same left hand curve on the county road leaving the house, about 50% of the time. Oh well. I'll take it. Thanks again for the help diagnosing.
Old Aug 16, 2024 | 09:03 AM
Change the other hub, they die in pairs!
desertrat
Sep 15, 2023 02:13 PM
gsalkowski5
Jul 23, 2021 06:37 PM
Retrokid
Jul 11, 2019 06:13 PM
Daytonablue06
Jul 26, 2010 08:45 PM
Marcruger
Oct 5, 2009 06:32 PM
