3rd brake light sockets burned
Old Jul 28, 2013 | 10:31 PM
blacky's Avatar
Two middle bulbs failed to light on 3rd brake light.
Turned out all 4 bulbs were ok, but sockets were cooked, especially middle two. Obvious contact resistance.
Old Jul 29, 2013 | 08:20 AM
time for a replacement of the sockets, fun wow!
Old Jul 29, 2013 | 11:40 AM
Radco's Avatar
Like Blue said sounds like a new socket is needed! What happens sometime's is corrosion get in the socket causing a poor connection , which cause's overheating, a loose connection can also do the same! While checking make sure all connection's are tight. Please post on what you find and what you do!
Thanks
Old Jul 29, 2013 | 11:50 AM
blacky's Avatar
No. Cleaned up contacts, flooded sockets with WD40, popped in new bulbs (filiments ok, but contacts not worth fixing up) and good enough is good enough.
Since all 4 sockets were cooked, parts are bad; or perhaps, but not likely, bad assembly. Tons of tan grease was packed into sockets. Dissimilar contact metals could be underlying culprit.
Since unit is in nice environment inside car, I would expect essentially infinite service - based on experience with 20 - 30 y old cars.
Old Jul 29, 2013 | 01:14 PM
Good deal. But keep an eye on them anyways, as I have had overheating issues like that with tail light bulbs, melting the plastic around the metal bases, requiring new tail light assemblies. And they weren't cheap.
tip for you: to clean the contacts on the end of the bulb bases, rub them on the sidewall of a tire - it cleans and burnishes the contacts nicely.
urbexHHR
Aug 22, 2020 07:40 PM
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
WohooTheWOO
Jun 26, 2014 07:27 AM
63falcondriver
Jul 31, 2012 08:49 AM
