ac clutch problems, codes, rear hatch won't open
Old May 13, 2018 | 07:41 PM
This works best when you communicate clearly. Take your time, use punctuation. I cannot be certain what problems you are now having.
Since you didn't update your other threads, they may be related. I have merged them.
Old May 13, 2018 | 10:20 PM
Originally Posted by donbrew
What language is Google translate butchering?
again.
Old May 13, 2018 | 11:55 PM
Without the COMPLETE code, including the alpha prefix, about all we can do is guess.
If the "14" code actually is the p0014 code, that refers to the Exhaust Camshaft Position Actuator Solenoid - many codes will disable the A/C as per OldBlue's previous comment.
If you are looking for more info or suggestions, you really REALLY need to create sentences, and use punctuation - as trying to translate your posts such as the last one is pretty much impossible to figure out what you are trying to tell us.
Old May 14, 2018 | 08:28 PM
roadmap's Avatar
sorry got the right codes
po014 po102 ,po113 ,po300 ,po351 these codes came of my 2009 hhr lt 2.2 obt11 there was 2 codes that changed po300, po351, now these are the new po172, po353
i did put on new mass air flow censor and changed the 2 new valves intake ,axhauth these were also new
i have not had a chance to take her out for a test drive. while atempting to remove the battery for a test the rear latch won't open that took a couples of days to figure out.
so far i put a new finger pad i check it the junk yard it worked ok..now do you all give me help the actuator is almost 200.00
al i can find is how to install to actuator not how to runs some test and see...
thanks to all thanks for the big welcome
Old May 14, 2018 | 09:11 PM
now do you all give me help the actuator is almost 200.00 ???????
I'm out.
Old May 15, 2018 | 08:52 AM
There is a wire shorted out or loose somewhere. Has somebody been messing with wires under the hood, like after-market alarm or immobilizer?
As to the hatch. Make sure there is NO fuse in #11 under hood fuse box. There IS one in #10.
Evidently, you need a Owner Manual? There is a link in my sig to get one for free.
Old May 19, 2018 | 08:52 PM
roadmap's Avatar
final fix
the codes that were showing..po014, po102, po113, po300, po351,.. this
is new to me different. now i first ask about ac. just checkingit was fixed with a little pag oil freon.
these codes still were there the ac was fixed
now the mass air flow was replaced new did not see any change from codes..next i went the buy the the new valves there was 2 intake and exauths it seemed to help still the sames codes coming up it was bad (the coil) was number one at first changed it to 3 that noticed a slight improvement still both the same you tube kept saying plus man the plugs look good but i followed the pros. do not forget a new air filter so now the codes are gone i took me time
this time was about 6 weeks i ordered from china i only purchased new
i know i forgot something was i can not figure was item fixed it
oil change next got a gallon mobil one full now try to fix the mess it leaves on the drive way
this rear actuater went out put new parts i remember hitting a bump nothing yet
sky
Mar 22, 2018 10:44 PM
tsmitty
Nov 29, 2017 06:15 PM
esmarkey
Jun 2, 2014 10:08 AM
Seca650RJ
Nov 2, 2008 12:02 AM
1HotHHR
Sep 14, 2007 06:56 AM
