ac/ heater controls
Old Dec 29, 2013 | 10:31 PM
flstss's Avatar
ac/ heater controls
on the controls there are two modes 1 fresh air coming in and 2 recirculating air. the fresh air in button is lite and when I push the recirculating air button that light blinks while the fresh air stays on then the blinking stops and goes off. so I can't turn on the recirculating air. anyone have any ideas about this?
thanks scott
2009 hhr
Old Dec 29, 2013 | 11:00 PM
I'll have to dig into the FSM, but I believe that the failure to switch modes and the flashing mode indicator mean you may have a problem with the blend door or its actuator.
Old Dec 29, 2013 | 11:08 PM
No, it's normal.
Can't remember the sequence but it's something about the selector has to be in a position that uses the AC compressor(AC or defrost) or something along those lines.
I remember thinking mine had a problem also but saw a thread on this site about it. It was a few years back.
In other words. Recirculation doesn't work in all modes.
Old Dec 29, 2013 | 11:12 PM
You're right George, haven't needed A/C or Recirc in either NC or DC for a while now, it's amazing the things you forget.
Please disregard post #2 Scott.
Old Dec 29, 2013 | 11:16 PM
I prefer the 'fresh' setting, with A/C or heat.
But if I switch to 'recirc' air the A/C turns on.. IIRC..
Old Dec 30, 2013 | 12:00 AM
Lucky's Avatar
Recerulation mode is locked out when the defrosters are on. The theory is that when defrosting the windshield you want heated fresh air in so that the moist cold air can be pushed out of the passenger compartment.
On the hhr the recerc button flashes to tell you that the command is not possible
Old Dec 30, 2013 | 06:45 AM
Use the SEARCH box at the top of the page to find a digital copy of the Owner Manual for your HHR on this site. Most of your questions are answered in it.
Old Dec 30, 2013 | 09:43 AM
flstss's Avatar
Duh!! had the selector switch on floor. put it to vents all is good now..
Old Dec 30, 2013 | 10:08 AM
Silverfox's Avatar
Congrats,
You just passed the HHR Cubix Test.
SF
Old Dec 24, 2018 | 12:59 PM
glassdave's Avatar
thank you search feature lol . . . . had this exact issue and was alllllll ready to start a thread . . . so basically nothing is wrong with the thing i thought there was something wrong with
