AC problems 06 2.4
AC problems 06 2.4
The ole ladies AC quit working. 06 2.4
The clutch kicks in, and the RPM drops like it's working. But hot air blows.
I let some 134a out and tried to put some in. No gauge, but it didn't take much if any 134a.
Any ideas what I should check? It just quit working out of nowhere.
My advice is to start over. Evacuate the system and pull vacuum for 30 minutes. The system holds 14.4 ounces of R-134a, but add 16 ounces to account for what is in the gauge hoses. Carefully weigh the cans to get his right on a kitchen scale. If there are no leaks in the system add an ounce of oil to be sure. IF you have a good compressor the air temperature should drop 55-60 degrees. This is how I do systems with success every time.
roadmap
Aug 16, 2018 02:09 PM
