Which actuator do I need to replace?
Old Aug 14, 2020 | 08:44 PM
Danman03's Avatar
Originally Posted by Oldblue
Cold to Warm would direct me to the temperature blend door.
That’s what I was going to go with too
Old Aug 14, 2020 | 09:39 PM
Why do you think I bothered hi lighting. There is a hose that goes to the side windows , an outlet for the defroster, one long duct to the end vents one duct for the center ducts and a duct to the foot
Old Aug 14, 2020 | 10:10 PM
Danman03's Avatar
you may have highlighted them, but it wasn’t clear in your description, which is why I asked the question I did. Since there is one outlet for the defrost, it should have the same air temp all evenly across. I’ll have to see if I can find anything obstructing it, but if there is, I would think the air flow would be less as well and not the same throughout.
Old Aug 15, 2020 | 12:28 AM
Oops. Sorry R J . I just saw that you had posted the same thing I did, except your's was 1st. I didn't see yours before because you had that part of your post under that diagram pic.
Sorry again.
No worries, brother
Old Aug 16, 2020 | 12:28 PM
Danman03's Avatar
I replaced the air temp actuator and it didn’t fix the problem. I moved the blend door by hand and I couldn’t tell anything off about it. It opened and closed and it didn’t seem like anything was loose or flimsy.
Zala
Sep 9, 2024 07:09 PM
DIYGuy
Dec 24, 2021 07:05 AM
Chevyred2008
Jan 7, 2020 03:23 PM
topgunn
Aug 31, 2016 02:41 PM
Gsus
May 19, 2014 09:48 AM
