Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
2009 hhr lt.
my problem,
my rear hatch it will lock
but nothing else works
I went to the junk yard
I got a 09 actuator
after testing both the white and black wire was hot
I also tested the hand switch it showed both had continuity,
but i removed it
I had it locked manually, I ran a direct line from the battery, and it works every time.
When I checked for the fuse,
I did not find any fuse out of place
I took pictures of 5 different cars in the junk yard
the fuses look to be all the same
now if i can find the problems
Reason: Attempting to decipher problem
It seems the rear hatch latch actuator is not functioning, power to both black and white wires. But a jumper wire will allow normal function, it could be the soft button switch in the rear beauty bar.
it could be a loose ground wire!
thanks for all the post. one post did it.
ok the relay was in the wrong place
i just took a couple of pics and found what one was keeping it from working
i know my typing was bad
lets close it and move to the next problems
2. i want to say all the codes are fixed also
no codes are popping up now those questions i had are fixed
working now. just i fixed along the way
