Adding keyless entry to a 09 LT
Old 07-01-2018, 06:33 PM
bal07hhr's Avatar
Did a search and couldn't find whats involved in adding keyless entry to our 09 hhr. Thanks for the help!
bal07hhr is offline
Old 07-01-2018, 07:13 PM
All HHR’s have keyless entry, first check your options sticker inside the glove box door, look for option AP3, then you can check your DIC and ensure remote start is on.
If you have AP3 then you also have remote start.
If your HHR came with FOBs but they don’t work, change the battery it’s a CR2032.
If you have AP3 but no FOBs you will need, FOB # 15114374.
There are many threads about cleaning soldering the battery cage, and so on, in the search window.
Oldblue is offline
Old 07-01-2018, 07:14 PM
I thought all HHR's had keyless entry...
Greybeard999 is offline
Old 07-01-2018, 07:16 PM
Yes, they do, it’s the remote start that is deleted from rental fleet and standard transmission.
Oldblue is offline
Old 07-01-2018, 07:32 PM
Maybe the question is how do you get a fob to work?
Go to any auto parts store or eBay or Amazon and get a new fob that includes the programming module.
Like this:
Amazon Amazon
donbrew is offline
Old 07-02-2018, 09:24 AM
That Amazon link states doesn’t work with an 09 HHR. But I’m sure Dorman and others supply a fob for your application
Oldblue is offline
Old 07-02-2018, 09:32 AM
The reason it says that is that it is 3 button. But that's why I said "Like this", I didn't care enough to do a deeper search.
donbrew is offline
Old 07-02-2018, 09:47 AM
Ahhh, I dig it!
Oldblue is offline
Old 07-02-2018, 05:44 PM
bal07hhr's Avatar
Thanks a lot for the help- really appreciate it!
bal07hhr is offline
Old 07-02-2018, 07:27 PM
Did you fix it, order a new FOB? Determine if you have remote start?
Enquiring minds want to know!
Oldblue is offline
Quick Reply: Adding keyless entry to a 09 LT
