Alignment performed, car still pulls left.
Old Apr 24, 2012 | 06:46 PM
Originally Posted by TomsHHR
Bac in my alignment days having one side differing from the other by 30 degrees sounds way off and they are attempting to correct the pull. I noticed the same pull to the left in my 2006 hhr, it was never corrected after 3 attempts with an alignment. even new tires did not correct it.
My impression is the hydraulics with the electric steering is not properly centered. as an example on a r/c car, boat or plane, you can adjust the steering of the wheels or rudders with the trim on the controller.
Where exactly does hydraulics come into play on an HHR steering? Do you mean water sheeting on the road? Do you mean lack of grease in joints? Electric Power Steering does not mean that there is an electric hydraulic pump, it means that there is an electric motor assisting the steering shaft.
I think that GM may have just over corrected for torque steer. Or,...... parts are worn out and the technicians involved don't, won't, can't look at the correct parts.
And, I will take the heat one more time; THE ONLY STANDARD ADJUSTMENT TO AN HHR LS/LT FRONT END IS TOE! You can add a camber kit (maybe SS comes with). From the factory the only available adjustment is the front toe, if the rear toe is out you can do shims at your own risk. You should never have to worry about camber or caster on an HHR unless you A) race B) install different than OE tires/wheels C) lower or raise the body using the suspension vs. shimming the body panels, if that is even possible!!!!!!! All of the other parameters are set on the engineer's drafting board and take extreme measures to change. Sorry for the Exclamation Points.
Old Apr 24, 2012 | 08:12 PM
Originally Posted by goodies
That's why I said OOPS it is .15 not 15 read to the end of the post
and that is why I said "TG for the correction - LOL" -
catncarp
Aug 1, 2022 04:54 PM
Blue Beast (aka Boydie)
Apr 14, 2015 01:51 PM
Al Chapman
Nov 30, 2014 04:22 PM
JAMIROBri
30
Oct 29, 2012 09:48 AM
chuckbear
12
Sep 27, 2010 08:36 AM
