Alternator
Old May 22, 2013 | 01:34 PM
Cellphone or GPS charger left in overnight?
Old May 22, 2013 | 01:42 PM
solman98's Avatar
You should be charging at 14-14.5 volts. If less, bad alternator or regulator. Check all connections first.
Old May 22, 2013 | 01:53 PM
Not 14.5 volts..............14 .5 Amps
Battery is 12 volts. Electrical components draw the power in Ampheres
Boydie
Old May 22, 2013 | 02:23 PM
db/sb's Avatar
Boydie, would you like to reconsider that post??
Old May 22, 2013 | 03:09 PM
jay loukakis's Avatar
Just a comment about batteries, when on charge the battery starts to gas at 2.36 volts the battery is being charged and mixeing the acid, if a shorted cell that cell voltage will shoe a very high voltage, my comments are for a flooded flet plate battery, there are others, gell cell, agm. the 2.36 volts is per cell, 14.16 and will go higher.
Last edited by jay loukakis; May 22, 2013 at 03:11 PM. Reason: the 14.16 is for a 12 volt battery flat plat battery.
Old May 22, 2013 | 03:10 PM
No. Check the fuses in your car. They are 5 amps, 10 amps, 20, 25 etc. We used to put amp and oil gages in cars that had the red idiot lights.
Boydie
Old May 22, 2013 | 03:18 PM
And:
Electrical guru Mark Hamilton of M.A.D. Enterprises points out that amperage is a measure of current flow, so an ammeter is actually a "flow meter" that's intended to measure current flow to the battery (under normal conditions) or discharge from the battery (in the case of alternator system failure). On a typical flow meter, all output must be directed through the device to obtain an accurate reading. In the ammeter's case, that means all the alternator output used to recharge the battery must first be routed through the ammeter under the dash. Which requires a heavy-gauge cable and presents a possible fire hazard. And the ammeter itself must be able to handle all this current flow, so it must have a higher current rating than the alternator's maximum rated output.
Boydie
Old May 22, 2013 | 03:26 PM
Alternaters range from 150 to 400 amp output bacause of all the electrical equipment in todays cars, if you have a lot of audio stuff, high- sub woofer you need more larger battery and alternater.
Old May 22, 2013 | 03:30 PM
SpaceCowboy's Avatar
Boydie
could you show us with a DVOM and show us the points where you hook it up
Old May 22, 2013 | 03:40 PM
Originally Posted by lesserdawn
I am having power issues with my 2006 HHR. My car kept dying so I replaced the battery but it kept dying. Now I have replaced the alternator twice. The alternator is sending 13 amps back to the battery and the battery is charging. But my battery keeps going dead. Any Ideas?
Really sorry that you are experiencing this issue. I can understand how that can be very frustrating. I would like to do further research for you to find out what may be causing this issue. Could you please private message me your name, address, vehicle identification number, and current mileage?
Thank you kindly,
Jessica L.
Chevrolet Customer Care
