Automatic Transmission
Old May 2, 2018 | 07:35 PM
Brian_DC's Avatar
I have just purchased a 2007 Chevrolet HHR LT model and I am having trouble with the high gears in my automatic transmission. The HHR doesn't shift into the higher gears as it should when driving.
I am not sure if it is an electronic issue or a transmission issue. Can anyone give me some insight? What could be causing this and what should I check first?
Old May 2, 2018 | 07:48 PM
Welcome to the site, check for a loose connection at the TCM and the ground wires.
Old May 3, 2018 | 07:03 PM
Brian_DC's Avatar
Thanks Old Blue. I have been investigating and have found similar fixes for this problem. I have also found that it the TCM has been touched by a hot wire while being maintenanced that it will need to be replaced. Is this true? How much will this replacement cost?
Old May 4, 2018 | 08:48 AM
Let’s confirm the problem first, then get into the parts, but they aren’t that expensive.
Herbie
Maintenance and Upkeep
66
Jul 7, 2014 10:52 AM
Lone Ranger
Mar 17, 2014 09:43 AM
wingfeather
Feb 4, 2008 07:56 PM
wingfeather
Jan 21, 2008 10:31 AM
Heartbeat
2.4L Performance Tech
Aug 15, 2006 08:51 PM
