Battery cable
Old Feb 18, 2023 | 10:34 PM
greg8453's Avatar
Originally Posted by Lee3333
Does anybody know what gauge battery cable we have? I need to install a switch to disconnect my ground until I figure out where the parasitic drain is coming from and I want to use the proper size It will be 4 feet long
Thanks
You want it to carry the correct current. A cable of 1000 strands will carry half again the amount of current a cable of 100 strands. Both being the same gauge.
Old Feb 19, 2023 | 09:02 AM
If your HHR is a 2008 disconnecting the battery will kill the TPMS, unless you already got the firmware update.
Frequent parasites are OnStar and EVAP testing and sound equipment. Check the I/M readiness, if EVAP is "not ready" it runs testing when the engine is turned off until it passes. Every time you disconnect the battery the testing has to start over from a blank slate, EVAP can take about 10 days to finish.
Old Feb 19, 2023 | 09:58 AM
And I see Lee is in NY. If emission testing is coming up, he better get this figured out quick. Or is it just NYC that tests?
Old Feb 19, 2023 | 11:03 AM
Lee3333's Avatar
Thanks for the info. Mine is a 2006 so I don't have the 2008 issues. I no longer subscribe to OnStar could it still be draining? How to check I/M?
Thanks again
Old Feb 19, 2023 | 12:46 PM
lazaino's Avatar
Pull the battery cable and connect a small light bulb between the cable and the battery. pull fuses till the bulb goes out and you'll have found the culprit.
Old Feb 19, 2023 | 05:46 PM
Any code scanner can check I/M readiness.
OnStar might try "calling home" even with no subscription, pull fuse #56 under hood, unless you use XM/Sirius (same fuse).
Nabco
Feb 16, 2023 05:14 PM
OKIE SS
Jan 26, 2018 11:35 PM
Trex08
Dec 2, 2016 09:57 AM
marilynferguson95
Sep 1, 2016 01:50 PM
HHR_SS_QC
Oct 10, 2009 05:14 PM
