Battery died
Old Apr 2, 2017 | 08:38 AM
Others from Florida have reported the same experience. I wonder if the regional battery factory might just be bad.
Old Apr 2, 2017 | 07:55 PM
My battery died in Florida! It might be all those pace makers from those Snowbirds!!
Old Apr 2, 2017 | 08:26 PM
Laco's Avatar
The battery in the HHR is in such a convenient location, I just got into the habit of replacing it between year four and year five. I can at least change it at my convenience that way, rather than when stranded somewhere.
Old Apr 3, 2017 | 07:05 AM
aradmahogany's Avatar
Like I posted before, much with alot of other things, I must be lucky! MY car has only had the battery replaced once in its 200K mile life so far! Though, the replacement is an OEM AC Delco, maybe better quality? Since the bat is in the back I dont think it would be effected too much by heat.
Old Apr 3, 2017 | 08:16 AM
Miles don't count for much to batteries.
Old Jul 15, 2017 | 01:29 PM
Conax's Avatar
I have a question for the forum, does anyone know the typical drain of a base model HHR when its parked? I saw a reference in some manual or other that the car needs to be driven regularly and not left parked for more than 5 days (I think it was).
My own new (used) HHR has a fresh looking battery, not a Delco, and its voltage drops to 12.3 after only 2 days sitting.
If I knew the typical drain of a car in good working order I could test mine to see if I need to
A) replace the battery
B) track down the leak
C) drive it more often or leave it on a battery tender.
I suspect all this computerization sucks on the battery harder than an older car would.
It's always 'on'.
Old Jul 15, 2017 | 02:14 PM
It's always 'on'.
a couple years ago in 2013 my hhr sat for an entire week on the factory 2006 battery and fired right up when I got back. Security system was enabled as well so I suspect you might have a leech of some sort?
Old Jul 15, 2017 | 02:29 PM
Conax's Avatar
I suspect it does. I'll have to pull the domelight fuse and take a reading on it.
I'll probably do it tomorrow if I get the chance.
That's why I asked about the normal milliamp draw of a resting HHR, so I can decide whether or not there's a problem. I'm glad to hear they can withstand at least a week of non-use when they're healthy. I just now pulled the onstar/XM fuse #24 to eliminate them, never will use them anyway. If there's no ill effects I'll leave that one out.
Thanks for the reponse.
Old Jul 15, 2017 | 02:44 PM
I know that disconnecting the OnStar module will cause much anxiety. Also there is a TSB about OnStar draining the battery, If I get time I'll look for it.
Old Jul 15, 2017 | 02:50 PM
db2006's Avatar
Originally Posted by aradmahogany
My 2006 HHR's original battery lasted 11 years, so I replaced it with an OEM AC Delco Battery hopefully to last another 11!
Same here. I just replaced the original battery in January.
