battery shorts out after charging
Does it short out or discharge?
Short out means you have a positive wire going directly to ground, probably with sparks and heat.
Discharge means something is drawing all the available charge from the battery.
Had anyone been messing with the car just before this problem manifested? Either bad battery or a wire connected to something wrong, like chafed insulation.
kmcrae476
May 25, 2015 11:19 PM
