Battery went completly dead, now instrument cluster is not working
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
All of the feeds to the IPC are digital. (network)
What is "an o2 sensor code"? Why did the battery "go dead"? When jump starting did either clamp ever make contact with anything it should not have? Look at all of the fuses marked "BCM" underhood; #4, #6. The maxi fuse next to the battery. (my bet) If a new IPC was installed programming is needed. Did somebody think that plastic ring around the ground cable is trash?
Actually I am not that familiar with Jcase fuses like the ones uses in the HHR, does anyone have a picture of a blown Jcase fuse vs a good one, maybe I missed that while I was checking fuses.
