Bcm/LED
The last time ut worked was 5 years ago i had an intoxolock put in my car. It has now been removed. And i riged the hood switch so it would think the hood is shut and the clicking i hear is starter silinod and the starter it self.. 06 hhr 2.4l and ap3
Not really sure why a new thread was started for this when it is just a continuation of the OP's original issues. This thread should be combined with the old one listed below so we will know all the previous info.
The OP's other thread=https://www.chevyhhr.net/forums/prob...d-57400/page2/
Do the lights flash?
By rigging the switch what do you mean? You know that it goes to the BCM right? It is not a simple on/off switch.
You want pin A open and pin B and pin C shorted. For cars without AP3 you ground the purple wire at the BCM to enable RS.
I am suspecting something to do with the theft control system. Check your PM, I will send something to read.
Possibly part of the disabler is grounding the pk/bk wire somewhere out of sight.
As you can see here; the starter either has power or it does not there is no way the solenoid can throttle the 12V.
jvm051
Nov 29, 2009 03:08 PM
