Belt noise.
Old Mar 9, 2007 | 04:46 PM
Snoopy's Avatar
Hillsdale......do you have access to a stethescope??? Those things the doctor listens to your heart and lungs with. Old "shade tree" trick. Use them as a probe to locate the position/cause of the noise. If you do, be careful not to get caught in the fan.
I also, have seen really good tech's use a piece of plastic conduit. It's not flexible so you need to be careful it does not contact two locations at the same time.
Sorry, again for the problem. Maybe the previously tightened bolt worked loose.
Old Mar 9, 2007 | 04:47 PM
Well, I just got back from the video store and the noise is back. Called into service and will be taking it back in on Thursday. This is getting old already.
Maybe it's the same bolt that keeps loosening up?
Old Mar 9, 2007 | 07:00 PM
(Loose Bolt Again) We'll see Thursday.
Old Mar 9, 2007 | 07:45 PM
Black Rose's Avatar
Is it a chirping noise that is sometimes there and other times not? Usually on really cold days?
If so, it could be that big hunk o plastic on top of the engine vibrating. Mine does that. Have to pop the hood and touch it and it stops.
You have to wait until next Thursday to get it in for service?
Old Mar 9, 2007 | 07:48 PM
Thursday because I'd rather half the other half take it in and thats the soonest it works for his schedule
Old Mar 10, 2007 | 07:57 AM
ChevyGrlAlways's Avatar
lol hills sorry i am laughing but i really do feel for you on this
Old Mar 11, 2007 | 11:08 PM
Post
If the problem is a bolt that continues to loosen..
It's time for adding some "Loc-Tite" & be done with that....
Old Mar 12, 2007 | 12:48 AM
Snoopy's Avatar
Last I remember, way back in my engine building days, the harmonic balancer bolts had a torque spec. Maybe that's not being done. If it is torqued to spec. then something is wrong that is causing the bolt to loosen (stripped threads?).
Old Mar 17, 2007 | 10:38 AM
Well, the car went in Thursday and amazingly it didn't make the noise! It was warmer out. They said they will keep the record open and to come in if it starts to do it again. Well, its colder this morning and making the noise again. Unfortunately the shop here is not open on Saturdays!
Old Mar 17, 2007 | 10:39 AM
But of course!! The gremlins know when to come out and play!
