Black Tail Pipe
Old Aug 22, 2017 | 03:39 PM
Maitaman's Avatar
Black Tail Pipe
Ok,so I just took a trip from Minnesota to Maryland. My factory Exhaust didn't have a chrome extension on it. i had my local exhaust shop put one on. After 2,500 miles driven my tail pipe is jet black like it was a diesel. I have a 2007 LT 2.2l with 155,000. I change oil when i should. I don't know about the pervious owner. Question is.... would this be normal for age and milage. Thanks
Old Aug 22, 2017 | 04:46 PM
Welcome to the site, very normal, check the hose the goes between the valve cover and the rubber elbow at the throttle body. By your description it's going to have oil in it, sucked into the Throttle Body
Here a link to a solution I posted awhile ago, seems to work.
https://www.chevyhhr.net/forums/2-2l...ormance-58332/
Old Aug 22, 2017 | 05:53 PM
Is the coolant under the pressure cap disappearing?
Old Aug 23, 2017 | 04:39 AM
07azhhr's Avatar
Black soot on your tailpipe and especially if it is also on your bumper above the tail pipe can also be caused by running too rich.
Old Aug 24, 2017 | 11:47 AM
Maitaman's Avatar
thank you for your replys
Old Aug 24, 2017 | 12:00 PM
Snoopy's Avatar
It's probably caused by the Direct Injection. All vehicle manufactures that employ DI have the same result. If this is not the source,,,,,,see all the above.
Old Aug 24, 2017 | 12:11 PM
It's a 2.2, so no DI
Blue Beast (aka Boydie)
Nov 24, 2013 11:58 AM
ljump
Jun 27, 2009 06:00 PM
roofer1976
Apr 26, 2009 10:37 PM
bisho1p
Jun 21, 2006 09:37 PM
