Blower Motor was only on HI, now not at all
Old Jun 21, 2020 | 01:49 PM
hhr06NJ's Avatar
2006 blower was only working on hi. Resistor? ok I will get to it. NOW, not at all.
is it a Resistor PLUS? OR could it be still be just resistor?
is there a second fuse inside?
fuse in engine compartment is ok
and no water infiltration
since I owned for 10 yrs
Old Jun 21, 2020 | 02:07 PM
Resistor
https://www.rockauto.com/en/catalog/...+resistor,6557
other possibility
https://www.rockauto.com/en/catalog/...h+/+panel,4212
Send hellshotrod a PM he might have a good used one.
Old Jun 21, 2020 | 02:20 PM
hhr06NJ's Avatar
thanks!
happy Fathers Day!
Old Jun 21, 2020 | 03:54 PM
If you order new from RockAuto, don’t forget the discount code!
Old Jun 21, 2020 | 04:59 PM
Since this is a 2006 model you need to fix the source of the problem; the butyl seal under the cowl and I would bet your cabin air filter is soaked.
water comes in through the bad seal and drips through the filter onto the fan motor and the resistor pack. When the resistor pack stops working you have high only. You fan motor is likely also fried. And your passenger floor is soaked.
Old Jun 21, 2020 | 06:59 PM
Here’s a how to video which includes the part number for the patch, I know you mentioned in post #1 there’s no leak , so enjoy the video cause your heater resistor is telling us otherwise.
smittiesplace
Sep 20, 2020 10:42 PM
Keenan2789
Jan 23, 2016 06:54 PM
jdburruss
Jun 11, 2014 07:51 AM
deve
Jul 28, 2013 10:09 AM
cmp4001
Nov 30, 2010 12:21 PM
