blower motor stops and starts intermittently
Old Dec 1, 2014 | 12:29 PM
Originally Posted by RoadKill1948
I had seen several references to the butyl
patch leaking, but it doesn't look like mine 2011 ever had the butyl patch
Only applies to 2006, a few 2007.
Old Mar 21, 2015 | 04:08 PM
RoadKill1948's Avatar
Resolved Fixed Inttermittent blower motor
It has gone on for several months. It would run fine and then just quit. There wasn't a pattern. It finally failed and wouldn't restart after a short time. The fault was a loose HVAC relay. Mine is located on the fuse panel on the passenger side of the console. Several of the fuses clicked and seated when pushed. The relay was very loose and wiggling it would cause the blower to start/stop. Reseated the relay and all is fine.
Old Mar 22, 2015 | 02:15 PM
hhr06NJ's Avatar
this happened to me 2x also.
the 1st time the tech reached up behind the glove box to the fan motor and accidently hit the plug? it worked fine for a month or so;
then it happened again, this time i pulled the plug on the motor and did something to clean the connection.
been ok for 2-3 yrs now.
it MAY have been a rusty connection due to a leak before I owned it?
kniffen
Mar 6, 2013 08:13 PM
ed.chrysler
Mar 24, 2010 02:49 PM
tmerkle111
Aug 3, 2009 01:42 PM
