bolt size for oil pan?
As for the stud idea, you don’t need to worry about alignment as there are alignment pins in the block to line up the oil pan . If I recall correctly, the bolts have a 13 mm head , so they should be 10 mm threads about 35 mm long the thread pitch should be 1 or 1.25
