boost to 25psi and then knocking and CEL
Old Apr 30, 2011 | 04:12 PM
Chevy13's Avatar
It's knocking constantly? When was the last time you checked your oil? Lets hope you didn't spin a bearing
Old Apr 30, 2011 | 10:23 PM
hyperv6's Avatar
Originally Posted by russruth
I've never really paid too much attention to the gauge, but after getting it back from the dealer (and wanting to make sure for myself it was done right) I found a stretch of Olympic that is 3 lanes each way and for about 1/2 mile virtually empty. (In LA this is almost impossible).
So I went up and down it I think 5 times and each time it pulled the same.
20 psi in first, 25 in the next two gears and then dropped a little before I had to shut down and stop, though I'll admit with so much torque steer you do spend a lot of time driving and less time looking at any gauge.
Once again maybe my gauge is off, but the butt dynometer says it's good.
Now the only thing I need to do (knock on wood) is add some better tires than the oems.
IMO
Anything over 20 PSI is good on a Butt Dyno.
Old Apr 30, 2011 | 10:39 PM
IgottaWoody's Avatar
Codes? otherwise I'd be looking at the gas..what was the eng temp? 2nd gear is not that much of a load for gearing, you could probably pull out in 2nd and be ok...so I;d be looking at weak/water/or shyster tanker trucks.
Old May 1, 2011 | 12:33 AM
moonsign's Avatar
Must be bum gauge, or you're not reading it right. 25 lbs. of boost on a stage 1, ain't gonna happen. If it accidently does happen, you better watch your charge piping and intercooler end tanks. They have a habit of blowing up at anything over 24 lbs.
you gots a problem somewhere ,that the car don't like.
Old May 1, 2011 | 07:46 AM
foolmoon_design's Avatar
I boost between 24-25 consistantly, although I got other toys. GM told me it shouldn't go over 20-21, BPV is OK. But then again, I think I have one of the only SS's without problems. KNock on Wood!
Old May 1, 2011 | 08:04 AM
Mine does what GM said 20-21,running fine so far
Old May 1, 2011 | 08:06 AM
ChevyMgr's Avatar
Originally Posted by IgottaWoody
Codes?
Best place to start.
Old May 1, 2011 | 02:43 PM
russruth's Avatar
Whether the gauge is correct or not doesn't concern me.
What is nice is for the first time since the upgrade, it is solid, doesn't surge or buck, or throw a cel and goes like hell.
That's all I can ask and if in a year it pops something, well, I'll deal with it then.
Old May 2, 2011 | 07:56 AM
bad03xtreme's Avatar
Dropped it off at the dealer this AM so we shall see what they come up with. It runs fine until the boost gets to right about 25psi that when the engine knock happens.
Old May 2, 2011 | 08:25 AM
I bought my HHR from Andy of ADM so I am not sure if he had something done to get a bit more boost but I could easily hit 25psi when in any gear other than 1st. I never had an issue in the 2+ years of owning it but something happened Friday morning.
