Bouncing gauges and no start
Old Apr 14, 2016 | 08:42 AM
  #41
Have your charging system tested, it sounds like your alternator is failing, or conversely you got a defective new battery, or one not fully charged
Old Apr 15, 2016 | 04:12 PM
  #42
Xlh883's Avatar
Well got the system and batt checked out again and all is good according to the diagnosis machine. Guess I'll just have to wait and see how things go...
Old Apr 15, 2016 | 04:24 PM
  #43
Posting the voltage readings from your system check out would have been a good thing .
Old Apr 15, 2016 | 07:17 PM
  #44
Yes and now on with the investigation, check for loose grounds under the hood, in the spare tire well by the battery!!
I strongly recommend to disconnect the negative terminal on the battery!
The check and clean all the grounds, tighten the positive post on the fuse box under the hood, the one with the red plastic cap!
The reconnect the positive cable to the battery and lastly the negative cable to the battery
Old Apr 15, 2016 | 07:31 PM
  #45
Maybe even do the underhood fusebox fix.
Old Apr 15, 2016 | 09:11 PM
  #46
Xlh883's Avatar
Didn't even think about posting them. I'll have to find that sheet again.
I did check grounds when I did my oil and they were secure. Did not remove them though. I did also check the fusebox and there was a few fuses and relays that were loose. I also had cleaned the terminals and posts when I installed the new battery.
What fix are you talking about for the fuse box?
Old Apr 15, 2016 | 09:31 PM
  #47
Old Apr 15, 2016 | 09:35 PM
  #48
Xlh883's Avatar
I will have to watch this. Thank you
rhales
Jan 16, 2025 10:37 AM
hhrssz
Jan 3, 2019 09:32 AM
bursjon
Jan 20, 2017 10:09 AM
berky1976
Jun 14, 2013 12:32 PM
datekman
Mar 22, 2013 03:06 AM
