Brake & Cruise Switch Adjustments
Old Nov 16, 2020 | 02:31 PM
jjoverit's Avatar
Originally Posted by donbrew
Do the brake lights work when this happens? The cruise control will not work if the third brake light is not fully functional.
checked connections. No power at 3rd brake light.works occasionally when I slam on brakes a couple times. Usually 3 times. thinking about changing rcdl relay under hood on drivers fender
Old Nov 17, 2020 | 12:51 PM
You are wrong if you meant RCDLR relay. It might be the CHMSL RELAY, depending on the date of mfg.
The CHMSL is on a different circuit from the regular stop lights. It is a lot more coplicated than you might suspect.
Old Nov 17, 2020 | 12:58 PM
jjoverit's Avatar
Yes that's the one. I was reading about it somewhere on here. It's on the inside driver fender. I was gonna replace the relay. It's like 10 bucks. Worth a shot.
Old Nov 17, 2020 | 05:08 PM
A relay would not care how hard you hit the pedal.
Old Nov 17, 2020 | 05:24 PM
Again, sounds like a poor connection.
Old Nov 17, 2020 | 07:44 PM
  #26
jjoverit's Avatar
I know it's not really how hard I press it, more so as the amount of times. Usually takes 3 times. Works fine some times. Connection at the bulbs is ok, changed the pedal sensor, I'll check that connection as well. I figured swap the relay for a new one, didn't know if it was a bad relay or connection there, not sure
Old Nov 17, 2020 | 08:09 PM
  #27
You said you had no power at the brake light. Now you say connection at the bulbs is ok. Can you clarify?
Old Nov 17, 2020 | 08:14 PM
  #28
jjoverit's Avatar
No power but connection appears to look ok. No corrosion. Had vehicle running with brakes applied
kbelfry
May 14, 2015 01:08 PM
Doctuh
Maintenance and Upkeep
Mar 9, 2014 10:12 AM
myers1wa
Nov 20, 2013 10:02 AM
MGMsHHR
Aug 2, 2013 04:47 PM
WEB
Sep 3, 2009 09:16 PM
