cruise control not working
Old Nov 8, 2013 | 07:50 AM
myers1wa's Avatar
I bought a 2007 HHR and the cruise doesn't engage. The light comes on in the steering wheel but will not hold the speed, anything I can check myself before taking it to the dealer?
Old Nov 8, 2013 | 08:14 AM
Welcome to the site.
1st thing. Check all your brake lights. The cruise control electrical system runs through the brakelighting circuit. A burned out bulb will not allow the cruise control circuit to operate.
Old Nov 8, 2013 | 09:15 AM
myers1wa's Avatar
Are one of the two switches at the brake pedal for cancelling the cruise?
Old Nov 8, 2013 | 09:27 AM
Sort of.
the computer actually senses the light bulb resistance, If a bulb is out the cruise will not engage.
Old Nov 8, 2013 | 11:04 AM
oldracer's Avatar
I had this issue a few months ago and found one of the switches mentioned above had actually slipped and was not making proper contact since the little plunger was not hitting the stop. This was due to the bracket holding the switches had twisted slightly making the switch out of line. I replaced the switches anyways as they are cheap (Rockauto.com) and made sure they lined up. The alignment issue is a bugger to see, especially for an old guy like me!
Old Nov 8, 2013 | 11:16 AM
Doc brown's Avatar
Hidden CEL codes can prevent the cruise from operating also.
Old Nov 8, 2013 | 12:27 PM
Laco's Avatar
Originally Posted by donbrew
Sort of.
And if your HHR is a five speed, there is another cruise disabling switch on the clutch pedal.
Old Nov 12, 2013 | 02:56 PM
myers1wa's Avatar
I drove the car today and kept trying to get the cruise to come on, and lo and behold when I used my boot to lift up on the brake pedal with a lot of force, the cruise actually engaged. If I let up on the pressure I was exerting just a fraction, then it disengaged. It is definitely in those switches or the alignment. Thanks for the hint.
Old Nov 19, 2013 | 06:41 PM
myers1wa's Avatar
Adjusted the switches and everything is working fine, as far as the cruise control is concerned.
Old Nov 20, 2013 | 10:02 AM
Awesome, glad to see the issue is addressed and repaired.
bodywerks
Aug 28, 2016 04:07 PM
Britjoe
Maintenance and Upkeep
Jul 21, 2014 08:48 AM
dbldown
Feb 19, 2014 08:08 AM
hhrumadbruh
Oct 26, 2012 07:53 PM
niceguytim_98
Sep 19, 2011 11:16 PM
