Brake Master Cylinder
And use what's called a Flare Nut Wrench, because if you round off a brake line fitting, you're day will go straight into the "can't possibly suck anymore" catagory.
You can pick up a decent set of Flare Nut Wrenches at Harbor Freight in both SAE and Metric for less than $40.
And Don is correct, you'll need to move/remove the fuse box to gain access thank to the HHR's 10lbs in a 5lb sack underhood layout.
JLATKY
Apr 5, 2014 06:46 PM
