Brake Problem
Old Apr 25, 2015 | 09:27 AM
Don06's Avatar
I believe that the problem may be caused by rust on the rotors. If you look at the rotors after a damp day, you will see signs of rusting. The rust may be worse between the pads and rotor as the pads may hold the moisture and the metal in semi metallic pads may increase the rusting. Rust will cause the pads to have more friction at the rusty areas. If it rusts worse were the pads sit the pads will have more grip when that comes around. Since the front wheels turn at different speeds when you turn a corner, the rusty areas hit the calipers at different times so the right side brakes harder at one point then the left side shortly after then right, left back and forth causing the steering shake. If they happen to get in sync, the shake goes away until you turn again.
I've had some success getting rid of it by putting slight pressure on the brakes while driving down the mile stretch of straight road before I get to my driveway to wear the rust off.
The ultimate cure would be to use a material for the rotors that doesn't rust.
Old Apr 25, 2015 | 10:41 AM
Originally Posted by kellytx4
I am stuck on trying to fix my 2006 HHR's brakes. I have already went through 4 sets of rotors and twice as many sets of pads all in 160,000 miles. Some of them high performance drilled and slotted. Other sites and forums now are mentioning a TSB for HHRs built in Mexico, (also the Chevy Cobalt same said) is there anyone who has used the TSB to fix brakes, brake systems, I love my Champagne colored 2L, as does my wife, well it was her choice not mine. Now it shakes and shudders like an old cement mixer when I brake,tell me someone has an answer.
This thread died out in 2008. But there are hundreds of others on the subject. ALL HHRs were built in Mexico. I think the TSB you mean is about the water shield that was re designed around 2009, the new part is available and can be installed easily.
Most likely causes:
Poorly adjusted/worn out REAR brakes.
Bad lower control arm bushings.
Bad wheel hub(s).
The SEARCH tool at the top center of each page works pretty good.
Old Sep 26, 2015 | 11:00 AM
Pontiac1's Avatar
Again brake issue
I' ve got a dutch 2006 hhr with an auto trans and 2.4 l engine.
I replaced all my brakes. Delco discs at the front , delco drums and pads at the back. And still i have a vibration in my rear brakes. When i drive about 60 mph and i slowly put the parkingbrake on it vibrates like hell..
Every part is new. Even the fluid. anyone has an idea..???
Old Sep 26, 2015 | 11:03 AM
Pontiac1's Avatar
And i work for at a corvette/ chevrolet dealer in holland. And stil cant find a sollution.
Old Sep 26, 2015 | 03:47 PM
Double check the rear lower control arm bushings, if these are done they will show as a shake under braking.
I have just dealt with this I have the 11.65 inch SS non Brembo rotors and stock LS calipers up front and GM drums and shoes out back. I replaced my LS LCA bushings with K200792 Moog bushing/ bearing, the two piece part on the right is my old GM bushing, 4 years old and about 65,000 miles
Old Sep 27, 2015 | 10:26 AM
  #26
Pontiac1's Avatar
Thanks
Old Mar 27, 2016 | 01:04 PM
  #27
HHR_2425's Avatar
I was looking for information on the HHR brake shimmy issue. I worked for GM for 21 years. They had underengineered the brakes on the HHR and I believe Pontiac G6 brakes are bigger and fit so I was looking if someone had done it and had which parts they had to buy. I will try and find out more.
Old Mar 27, 2016 | 01:17 PM
  #28
Start by reading all of this thread and then using the SEARCH tool. Generally, there is nothing wrong with the brakes it's a maintenance problem. Self adjusters don't work well enough, rubber bushings wear out.
Old Mar 27, 2016 | 02:43 PM
  #29
HHR 2425 , welcome to the site, larger brakes up front are readily available , read here.
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
And keep your rear drum brake shoes adjusted
Old Mar 28, 2016 | 10:07 AM
  #30
HHR_2425's Avatar
Thanks Oldblue, thats is what I was looking for.
Donbrew, I found this message using a search, I only have so much time so I thought I would ask if anyone could help. Just so you know, I held a masters mechanic license for over 20 years and have 3 degrees. I have worked as both a technician and an engineer. This is not a maintenance issue. If the self adjusters don't work well enough, that would also be an engineering issue.
