Brake Problems
Old Jan 18, 2011 | 09:18 PM
10RedSS's Avatar
Brake Problems
So i have not even 3k on my SS now and I already had to bring it in for service. the brake valve module has to be replaced. the pedal almost goes to the floor and i have to pump the brakes to stop but then after that the brakes work fine, it doesn't happen all the time. anyone else have this problem? I have the performance package.
Old Jan 18, 2011 | 09:35 PM
hyperv6's Avatar
Not see anyone with this issue. Just one of those rare odd things.
Old Jan 18, 2011 | 10:03 PM
87silver's Avatar
Sounds like a "one-off" to me.
Old Jan 19, 2011 | 09:40 AM
Rod Run's Avatar
That's why we get warranties, because no one is perfect. It's more important to me to buy from a company stands behind their product when something goes wrong, than to buy from a company that "probably won't" have problems, but if they do, they don't stand behind them
Old Jan 19, 2011 | 09:24 PM
IgottaWoody's Avatar
Does this happen the first start of the day?
Old Jan 19, 2011 | 10:09 PM
10RedSS's Avatar
It happens whenever it sits for more than like 4 hours.
Old Jan 20, 2011 | 09:02 AM
skyeglen's Avatar
There was a problem with certain year SS brakes some time back. Something about adding a different vacume booster if I recall correctly.
There should be able to find several threads using the search.
Old Jan 20, 2011 | 07:33 PM
There is a TSB and a kit that fixes this problem....its only a start up issue with the SS as there is no vacuum to build up until the turbo settles down,, ( watch your boost gage and you'll see it) ...takes about 30 seconds and the gage will drop to 22 vac and all is well....
Old Jan 20, 2011 | 09:02 PM
87silver's Avatar
There was a thread on this some time ago. Check it out here:
https://www.chevyhhr.net/forums/hhr-ss-45/automatic-ss-brake-problems-dealer-results-17740/
Old Jan 21, 2011 | 09:17 PM
Interesting though as I never had the fix done and nows its been so long since this has happened I forgot about it....Even on cold mornings (20's) no problem....
drspock
Aug 11, 2023 04:08 PM
walkowg
Jun 16, 2013 08:08 AM
Clevelandhhrss
Jan 5, 2009 08:03 PM
REDHHRSS
Aug 14, 2008 09:29 AM
ny5112
16
Dec 29, 2006 09:28 PM
