brake shudder
Old Dec 10, 2017 | 01:05 PM
bailbud's Avatar
brake shudder
noticed the front brakes are vibrating when going down a long hill and they need to be held on , then they started to vibrate when stopping at stop lights . the front pads and rotors were changed 20 000 km ago . there is 100 000 km on the car . front end seems good
Old Dec 10, 2017 | 01:14 PM
Cat Man HHR's Avatar
Either you have a hard spot on a rotor and they're warped do to heat, as in over braking.
What brand did you buy?
Old Dec 10, 2017 | 01:34 PM
Or the rear brakes need adjustment!
Could be ball joints , rear lca bushings tie rod ends , steering rack gear loose.
Old Dec 10, 2017 | 02:40 PM
bailbud's Avatar
cant remember what brand, was 2 years ago when my father in law owned it
Old Dec 10, 2017 | 02:48 PM
bailbud's Avatar
pulled the rear brakes apart looked good , cleaned up the drums put everything together took it for a drive seemed better. had a power steering code unhooked the batt to clear the code not sure if that helped??
Old Dec 10, 2017 | 03:05 PM
Why not take it to a dealership and have the power steering fixed under the extended warranty/recall? No need to clear it as it will clear as soon as the fault (the motor overheating) goes away.
Dirty, out of adjustment rear brakes will cause shudder. You would be surprised at the difference new rear brakes makes after 150,00 miles, even if they "look" good.
Old Dec 10, 2017 | 03:17 PM
bailbud's Avatar
only 60 000 miles , will get it to the dealer soon
Old Dec 10, 2017 | 05:11 PM
Canada had a different recall/warranty from the US. I don't remember which the 2007 came under.
Old Dec 10, 2017 | 05:37 PM
I totally recall, it’s not a recall, it’s an extended warranty
https://www.chevyhhr.net/forums/gm-r...tension-50057/
The ‘07 is covered!
rcgem
Mar 14, 2017 08:11 AM
Doctuh
Oct 27, 2010 03:29 AM
Waynejwj
Mar 19, 2010 04:10 PM
Brucet
Jul 13, 2008 10:10 PM
jerij
Jul 13, 2006 10:18 PM
