Braking issue with potholes.
Old Nov 27, 2019 | 10:44 AM
kamikaze3557's Avatar
Happy Thanksgiving first of all
Been awhile sense my last visit and thanks to previous help from the form members that have saved me a lot of time and money , the ole HHR has been doing more than fine, but I now have an issue that I have no idea where to start.
Problem, whenever I apply brakes and in most cases to slow down for upcoming pothole the brakes go to the floor , but when I release the brakes and reapply they are back to normal...the brakes function as normal otherwise, I never slam on brakes and as long as the road is not to bad I can apply them somewhat aggressively (if needed) and they do a great job at slowing me down. (other notes, brake pads Ok, fluid level ok, no odd sounds when braking , or driving (I do have hearing loss tho))
Thank you,Mike
Old Nov 27, 2019 | 11:10 AM
A full inspection is in order , perhaps the master cylinder is leaking into the power brake booster!
check and adjust the rear shoe adjusters, they tend to not self adjust as designed.
check for spongy flex hoses , have your assistant apply the brakes while you observe the brake hoses front and rear.
Old Nov 27, 2019 | 12:06 PM
And stop driving it on the street. It's a dangerous situation.
How you even say it's a braking issue with potholes is beyond me. Stop driving it before you hurt or kill someone.
Old Nov 27, 2019 | 01:20 PM
I'm telling you guys, these things come in bunches!
Old Nov 27, 2019 | 01:38 PM
Thanks for the heads up ,advice Oh! sorry , I'm only taking it out for tests after any adj or tightening a fitting, bleeding etc. I understand how the post read Whopper, sorry to have upset you.
at the lower end of the road I live on, near by and about as un-populated as I'll find close...
Old Nov 27, 2019 | 02:33 PM
I bet you have never even considered that you have rear drum brakes. If they have never been adjusted the brakes can act that way.
Old Nov 27, 2019 | 03:06 PM
donbrew...after a go over with fluids and brake lines,I think it was the next thing I checked and they were good but needed adj.....anyway..to no avail...all my brake pads and shoes all look good,(maybe half worn)....emergency brake is working not much of a dead spot before engaging. but I think I will just have them all replaced , turn it over to a mechanic and let them deal with it...just to old and worn out, me that is
Old Nov 27, 2019 | 08:38 PM
To test the booster: engine off pump up the pedal hold pressure on pedal while starting motor. Pedal should go to floor.
If that is not the problem the MC is suspect.
Parking BRAKE should click 3-4 times olr they need adjusting.
dande54
Apr 12, 2016 07:02 PM
SilverGhst
17
Sep 16, 2015 08:05 AM
CarmanHHR
May 8, 2009 04:27 PM
rbabiak
Feb 12, 2009 07:58 AM
CGYHHRSS
Jun 21, 2008 10:20 AM
