Broken Exterior Handle
Have you removed the door handle screw that is accessed throught the hole on the door edge (should be a red dot covering the access hole)? It goes back on the same way it came out.
The door latch has 3 screws if on the door edge to remove and reinstall. The link I gave you showed how the cable should be properly installed.
ronconherr
May 11, 2014 03:27 AM
