Butyl Patch
Old Jun 14, 2021 | 12:28 AM
Allen P's Avatar
Butyl Patch
Hey, so I just found out that the "butyl Patch" under my cowl is completely disintegrated. For now I've put in a waterproof cloth cut to size over the place but it doesn't look like it'll hold. Is there a place where I can buy a new one (what's it called) or does GM not make that specific part? I saw the handful of DIYs on YouTube and just wanted to check before I do any.
Regards,
Allen P
Old Jun 14, 2021 | 05:33 AM
Make your own out of something stronger, like a piece of sheet metal. Then seal it in place with your choice of a quality sealant.
It will then last the life of the car.
Old Jun 14, 2021 | 11:17 AM
Lonwane's Avatar
That's what I did.
No leaks, no fuss
The butyl patch was an after build "oops" when it was discovered that water could/would get into the fan assembly.
Old Jun 16, 2021 | 04:08 PM
Snoopy's Avatar
When I had my HHR, I replaced the patch with aluminum roof flashing, of the appropriate size, from Home Depot. Lasted the 8 years I had the car and 2 or 3 for the next owner, who was a friend. re Don't exactly remember what I used to seal it, but I believe it was some type of butyl. I believe I even posted a picture if it is still around.
Old Jun 18, 2021 | 07:33 PM
Allen P's Avatar
I just finished the job using the same metal, aluminium roof sheets.
I cut it to size and used the 4 minute epoxy glue to seal it in.
Appreciate the help,
Allen
Old Jun 18, 2021 | 08:01 PM
Job well done!
R8drrob34
Jun 28, 2019 04:36 PM
Cliffs51
Maintenance and Upkeep
17
Aug 4, 2018 04:48 AM
onelon
Oct 4, 2016 08:14 AM
CruzHHR
Sep 29, 2013 09:27 AM
gsl54
Jun 29, 2013 04:15 PM
