a/c heater control
Old Sep 21, 2020 | 09:48 PM
Lee3333's Avatar
Originally Posted by hellshotrod
i have a lot of them lmk , color heated non heated ,,, thanks blue ,,,,,,
I definitely need one with heated seats
Old Sep 21, 2020 | 10:15 PM
Originally Posted by Lee3333
Here is the really weird thing. I did the dimmer mod 17 years ago. I only began having problems with the HVAC control about 5 years ago. None of the previous 4 panels had any melted plastic or burnt connections-the tan just would not work. And I have not touched any of the wires on my car in over 5 years. So why suddenly this issue?
Anyhow, both the wires from the dimmer mod are now disconnected. I installed an old panel I had and everything works except for the mas speed setting.
All so strange. Is my HHR haunted???
Coincidence? I think not.
Old Sep 24, 2020 | 04:38 AM
planetrj's Avatar
I was wondering if I could buy one from you. I don’t have heated seats, and I’m happy to pay whatever you’d like to charge me. I was really happy to find this post, just because I didn’t really know if this was a common problem, and here we are! Hahaha
All of the speeds except high stopped working. The A/C also stopped clicking on at the same time. So all I now have is just Off & High Fan.
Also, was wondering if you might have any of the speed knobs, because the rubber that’s facing up is beginning to deteriorate. Even just the outside rubber grip ring would be fine since the actual knob is okay.
Thanks so much if you can possibly sell me one!
-RJ
Old Sep 24, 2020 | 07:57 AM
If the fan has ONLY high and off the resistor is bad. If you have a 2006 or early 2007 the "butyl patch" under the windshield cowl is probably compromised.
Old Sep 24, 2020 | 08:47 AM
planetrj has a 2010, so yes it’s most likely the resistor, send hellshotrod a PM for that or order new from RockAuto and don’t forget that discount code!
Old Sep 25, 2020 | 07:49 AM
planetrj's Avatar
I appreciate that info from both of you. Yes, I have a 2010 (as I’ve discovered by cleaning out the air duct, there’s no butyl - mine’s a metal piece). I will send a PM, and see what we come up with. If not, it looks like I’m going to be using the windows a lot more for a while. Hehe
Thank you!
Old Sep 25, 2020 | 10:04 AM
Ah! 4Sixty AC , all four windows down and 60 MPH to cool off!
Not recommended in city streets.
Old Oct 2, 2020 | 04:57 PM
Lee3333's Avatar
Well, s far so good. I disconnected the ground and power wires I used to modify my dimmer switch, And I installed an old HVAC control panel which wasn't working 2 years ago. And now it works perfectly. All fan speeds!
When I did the dimmer switch mod, the article showed how to add 2 wires to the plug and it said that it did not matter which wire you grounded or hooked up to the fuse box. But now Don said it does matter, so I must have had it wrong. Wither way, I am not anxious to get the dimmer switch to operate the courtesy lights. I am just happy the problem seems to be solved
Thanks to all the support from you guys, as always
Old Oct 2, 2020 | 05:23 PM
I didn't actually say it was wrong. But, I think the dimmer was the problem.
Old Oct 2, 2020 | 05:32 PM
I’ve often wondered why mess with the interior lighting, the dimmer switch relays thru the BCM to the lights, so yeah, it would definitely matter if you grounded a wire.
mikiec66
Maintenance and Upkeep
Oct 16, 2019 11:13 PM
judy1bob
Mar 22, 2013 09:53 AM
mn64falcon
Apr 13, 2012 09:19 AM
dustindell
Dec 8, 2010 10:21 AM
budokai140
Jan 4, 2008 02:38 PM
