A/C problem
A/C problem
I just replaced the head gasket on my 07 hhr. After reinstalling everything the car runs great, but now my AC only works on max air. When I turn on normal air the compressor will turn off, when I turn it back on to max air the compressor kicks on and blows cold air. I am sure it is a simple thing I missed when I reinstalled everything. Can someone help me figure what that might be?
Step one...Go over everything you unhooked under the hood when you pulled the head, it could be a connector that's not fully seated.
Step two...Have the codes pulled, it could be a bad temperature sensor, that will show up as an error.
Also, did you reuse the old thermostat, or did you install a new one? Odd A/C behavior in these critters can usually be traced back to wiring, the temp sensor, or the thermostat.
And check your coolant level, it sounds terribly obvious I know, but low coolant will trigger an "out of range" temperature condition that causes the vehicle to disable compressor engagement.
P.S.
to the forum!
P.S.
to the forum!
06gray2ltHHR
2.4L Performance Tech
Aug 1, 2009 10:45 PM
Black Rose
Dec 7, 2007 11:28 AM
