A/C System Knowledge
Old Jul 28, 2021 | 01:00 AM
TePL's Avatar
Where would I go to understand how the A/C System works in my Chevy HHR?
I must be bad at searching, I could not find a system diagram or general explainer on both this site or the general internet.
Old Jul 28, 2021 | 06:11 AM
Welcome to the site, in general the HVAC system is common to most GM vehicles, if you tell us some more about any symptoms you are experiencing, or any CEL codes we can assist you to resolve the problem.
Most areas of the system have been addressed over the years, so the threads and posts aren’t in one place.
Old Jul 28, 2021 | 08:10 AM
I don't know how you could have avoided all of the youtubes. I GoOgled "auto a/c". Here is one:
Old Jul 28, 2021 | 08:32 AM
Too put it bluntly, the HHR system works the same as most automotive systems have for many, many years.
If you're looking for general AC knowledge, then Youtube has many videos as Donbrew (the Invisible Man) has pointed out.
If you're looking for a specific HHR related AC problem, post up your question. We have several members that can help you with AC stuff.
Old Jul 29, 2021 | 06:46 PM
desertrat's Avatar
In my opinion, the HHR A/C system is easy to work on, excluding the electronics. Charging and replacing components is all straightforward. When properly charged the drop in air temperature should be 55-60 degrees out the vents.
JJ's BLACK SS
2.0L Performance Tech
Nov 13, 2009 12:28 PM
briand
Oct 7, 2009 07:14 PM
Cyclic Hardover
Jul 16, 2008 02:12 PM
max3456
2.4L Performance Tech
May 25, 2007 09:23 AM
mavpen
Jul 20, 2006 09:52 AM
